Results 1 to 20 of 24
Thread: Project: Guard Heavy Weapons
    Commander Cadian 21st's Avatar
    Mission, British Columbia, Canada
    Allright...I have 4 more Heavies to go (for my squads), then I'll start on my Chimera and then buy more Heavy Weapons. nevertheless, I thought that I should start a Blog on how they're coming. So, the 4 Weapons I have to do are: 2 Lascannons, 1 Autocannon, 1 Missile Launcher. As a note, I outright refuse to make them look just "standard shooting pose", and need to do some sort of conversion.
    1-Completed Heavy Weapons
    2-"Workspace" (note the heater...the garage is pretty cold this time of year)
    3-Primed Lascannon 1
    4-Lascannon 2 and Team (still need a "carraige")
    5-Possible Autocannon
ID:	4753   Click image for larger version.
ID:	4754   Click image for larger version.
ID:	4755   Click image for larger version.
ID:	4756   Click image for larger version.
    "Luck: that's when preparation and opportunity meet."
    Pierre Trudeau
    "The end may justify the means as long, as there is something that justifies the end."
    Leon Trotsky
    Re: Project: Guard Heavy Weapons
    Oh wow...I have the photo taking abilities of a 4-year old...
    ....And the "Concept Sketches", I'll scan better ones later. They may be coloured, but I doubt it.
ID:	4758   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Ok, so far today:
    - Attached head to "Joe" from Lascannon 2
    - Screwed around with Lascannon 1, adding bolter holes and making a mortar explosion thingie... (by the barrel)
    - Almost finished Gunner for Lascannon 1 (bottom left)
    - Finished Loader's Legs (Lascannon 1)
    - Tried out some "Ink-Spot" Camo on the wheels. (trying to mimic the scheme on the second picture)
ID:	4775   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Finished Gunner and Loader for Lascannon 1...pictures aren't working at all well. Tomorrow, I'll primer the crew and start painting the cannon (after some trials of course)
ID:	4811   Click image for larger version.
ID:	4812   Click image for larger version.
ID:	4813   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Here's the newer wheels:
    Pierre Trudeau
    Leon Trotsky
    Allright, here's some *better* pictures of the Loader, though they lack any real detail . The model's a pretty good match of the picture on page 56 of the Warhammer 40,000 Rulebook, though with different armour.
ID:	4832   Click image for larger version.
ID:	4833   Click image for larger version.
ID:	4834   Click image for larger version.
ID:	4835   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Here's the mostly finished cannon's camo. Most of the "environmental effects" are on it, but the final will be done just before explosion is fitted.
ID:	4840   Click image for larger version.
ID:	4841   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    - Better pictures of the Lascannon and the Wheels. If anybody cares about how I did it, then I'll do a tutorial on the base (which I happen to have lost a wheel mount for :'( it fell off today). I'll wait a few days to start on that, but I doubt anyone cares - especially with my picture quality, lol.
    - Invariably, whenever I've started ANY portion of this project, I've dropped/lost the part I'm working on. Right now I'm down a few Chem-Inhalers-one of which blew away when I was primering (it was windy today). I'm quite choked about it, but wtv.
ID:	4852   Click image for larger version.
ID:	4853   Click image for larger version.
ID:	4854   Click image for larger version.
ID:	4855   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Chapter Master FearFrost's Avatar
    Clearwater, FL
    I dig the "88mm" style lascannon mount. Your camera have a macro mode?
    -Brian
    - I'm not sure...how can I tell? It's a Kodak DX3600: 2.2 Megapixels, if that helps.
    - This is the 75mm PAK-40 model by Tamiya (1/35 Scale). Some bitz were swapped about and converted, but otherwise it's quite similar .
    Pierre Trudeau
    Leon Trotsky
    - Mmmm, more pictures. I got distracted and worked on a Kroxigor some more . Anyhow, I hope to get more done tomorrow - today was mostly spent laying tiles . Here's the Kroxigor, the Loader (another attempt...I doubt it'll look good till painted), the Cannon again, the team for Lascannon 2, and the beginnings of the Missile Launcher Team.
    (edit: oh wow those are bad pictures...I guess pay attention to the poses. I'll be getting a better camera, hopefully (I just got paid today, yay!) though I doubt it...lol)
ID:	4860   Click image for larger version.
ID:	4861   Click image for larger version.
ID:	4862   Click image for larger version.
ID:	4863   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Chapter Master old guard's Avatar
    Southampton UK
    Quote Originally Posted by Cadian 21st
    If you have a button with a picture of a flower.....press it thats the macro feature, it will require a very steady hand from that point so if you can rest it on something so much the better. If there isn't one obvious then (reaches real deep into the dark recesses of his inner being)..........read the instruction book before using the item AAARRGGGHHH!!!!!!!!!!
    I do have that! It's called "close-up", but drains the battery pretty quickly. I tried that with some of the Cannon pictures and it worked, erm, better...
    Pierre Trudeau
    Leon Trotsky
    Clearwater, FL
    For my recent Eldar pics, I just set the camera down on the table and tilted it a bit to get the shots I wanted...cheaper than a tripod
    And yeah, it might chew more battery, but good pics are worth it
    -Brian
    - Haha, I forgot to post last night . Anyhow, here's some piccies (one of which is pretty stellar) of the completed Gunner. I'm pleased with how it turned out, though a tad dissapointed in the Loader (who will be photographed when I get back this evening). I would have got more done on the other teams, I figure, if I hadn't had finished the Shanaeyn Army List, but better luck next time.
    - I did use the Macro feature, and I put it on a solid platform, but it still took 10 shots to get these Top 3 .
ID:	4936   Click image for larger version.
ID:	4937   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Chapter Master colhodg's Avatar
    Huddersfield
    Try setting up the camera up on a book or something, pointed the right way (or use tripod if you have one).
    Use the timer function so you're not actually touching the camera when it takes the pic - that way your hand movement won't cause the pic to blur when you press the button.
    Hmmm, I'll try that...and post yesterday's work tomorrow. My ISP hates me :P.
    Pierre Trudeau
    Leon Trotsky
    - Haha! I completely forgot about this! Anyhow...so far I've:
    - Repainted the squad
    - Finished Lascannon 1
    - Based all my minis...
    - I've still gotta add chem-inhalers to the squad, then I'll post a pic with the squad. I'll start on Lascaonn 2 when I find some plasticard, though I'll finish the crew for it and the ML.
    - Here're some, fairly good, pictures of my completed Lascannon. I took them on the macro setting with a strange apparatus (involving a ruler, a phone, and a few stacks of Post-It notes)
    (edit: awww, you basically can't see the rutts in the ground just behind the wheels...:'(. I burned my finger to make them!!!)
Name:	Julia - Grad 009.jpg
ID:	5459   Click image for larger version.
Name:	Julia - Grad 011.jpg
ID:	5460   Click image for larger version.
Name:	Julia - Grad 012.jpg
ID:	5461   Click image for larger version.
Name:	Julia - Grad 013.jpg
    Pierre Trudeau
    Leon Trotsky
    Errrk...I found some "in-progress" pictures that I never posts. You can dimly see the original squad colours...they were done a few years ago (I think 2 or 3), when I was still using enamel paint pens...you can see the little demons in the last picture.
ID:	5463   Click image for larger version.
ID:	5464   Click image for larger version.
ID:	5465   Click image for larger version.
ID:	5466   Click image for larger version.
    Pierre Trudeau
    Leon Trotsky
    Disgraced Inquisitor Captain Brown's Avatar
    Vancouver, B.C. Canada
    Cadian 21st,
    You might also want to use a picture editor to cut down on the size and try to sharpen your pictures. They are really, really large (1800x1200) and take forever to load and I am on a high speed connection.
    Captain Brown
    Disavowed Moderator...I can only move threads in MP&T and Project Logs now...I cannot revoke your warnings or give access to the Chaos Wastes.
    Elysian Army PLOG - Tau Army PLOG - Ork Army PLOG - Sisters of Battle PLOG - Necromunda Imperial Guard Army PLOG
    Please follow the rules and respect the opinions of others - Warseer FAQ
    Presently selling lots of IG bits - come see here
  1. Imperial Guard Heavy Weapons - Praetorian Style
    By Col.Gravis in forum M, P&T General Discussion
    Last Post: 19-03-2007, 03:29
  2. IG Heavy weapons
    By renevq in forum Warhammer 40,000 Rules
    Last Post: 14-01-2006, 21:21
  3. terminator heavy weapons?
    By Mars in forum Warhammer 40,000 General Discussion
    Last Post: 09-12-2005, 02:17
  4. Can you say - Imperial Guard Heavy Weapons
    By Gaebriel in forum Warhammer 40,000 Rules
    Last Post: 01-12-2005, 20:40
  5. Guard heavy weapons
    By super_steve in forum Warhammer 40,000 Rules
    Last Post: 29-10-2005, 06:13
