Results 1 to 5 of 5
Thread: First Terrain Project
    heya everyone i just got my hand on some balsa wood and was wondering what i should make with it. i have never made anything like this before so all help is appreciated
    thanks
    Re: First Terrain Project
    What do you usually play?
    What do you have an interest in?
    Do you need any type of terrain?
    Do you want any type of terrain?
    Kind of hard to just start tossing out ideas without knowing which way you might want to go to begin with.
    Daemonhunters: 7500 points Imperial Guard: 4600 points Space Marines: 3900 points
    Eldar: 5200 points Emperors Children: 4100 points Daemons of Slaanesh: 2600 points
    Sisters of Battle: 3695 points Grey Knights Only: 5464 points
    Play using No Limits rules set.
    Chapter Master bugbait_nz's Avatar
    West Auckland NZ
    Play 40k orks then one a dozen of these ? -> DOW WAAAAGH BANNER
    Bugbait out
    * Apocalypse Ork Plog * * Terrain building log * * Bugbaits Thunder Wolves *
    Old age and treachery will overcome youth and enthusiasm
    i play mainly fantasy my current army is Beastmen. the end goal is to make a 6 by 4 gaming table for fantasy and 40 with interchangeable parts. at the current time im focusing on the fantasy side.
    Well - with a supply of balse and Beastmen being your primary army - I would probably look at doing some timber frame type buildings.
    You build it up a lot like you would a full sized one - posts, beams, rafters and all that. Card stock replaces surfaces like the roof and walls between the posts. Start small, and play around with it. Nothing is more fun than pillaging an undefended village for a herd of Beastmen. If you screw up - don't worry...use it to practice doing damage and then you have a timber frame ruin.
