Results 1 to 20 of 22
Thread: las-plas razor and weapon destroyed
    Jan 2010
    Quebec
    I just saw that in the rule book faq
    Q: When a Damaged – Weapon Destroyed result is
    rolled and a weapon is destroyed are any built-in,
    combi or co-axial weapons attached to it also
    destroyed? (p61)
    A: Yes.
    So I was wondering what happens when you destroy a turret on a razorback that contains a lascannon and a TL plasma cannon. Are they not considered co-axial weapons, since they are on the same turret? Are they both destroy or only one of them?
    Chapter Master druchii's Avatar
    Columbus, OH
    Re: las-plas razor and weapon destroyed
    They're different weapons.
    Regardless of how the actual model LOOKS, they're listed as two separate weapons therefore they are.
    d
    My demons, the nightmares of Antioch IV:
    http://www.warseer.com/forums/showth...48#post5847948
    Want sexy demon on demon action?:
    http://www.warseer.com/forums/showthread.php?t=156939
    Jan 2010
    Quebec
    I just found out it is clearly state in the SM faq.
    Quote Originally Posted by VirtualSniper View Post
    A Weapon Destroyed result destroys one weapon. The Turret isn't a single weapon, it contains two weapons. Since there is no mention of them being co-axial, they are not considered as such.
    Culven
    Commander, Catachan XIII "Black Cats"
    "Pray that a Black Cat never crosses your path."
    We debate RaW, not in an attempt to gain an advantage, but rather to better understand the rules as they are written so that problems can be identified, addressed, and possible solutions developed before we get to the game table.
    Commander S_A_T_S's Avatar
    UK
    Just in case someone needs it:
    Quote Originally Posted by Space Marine FAQ Jan 2012
    Q: If a Razorback armed with a lascannon and twinlinked
    plasma gun suffers a weapon destroyed result,
    does it destroy both weapons or just one? (77)
    A: Only one weapon – either the lascannon or the twinlinked
    plasma gun.
    Knights of Baal: A Blood Angel Log
    WHQ Hall of Heroes
    WHQ Quarg Hunter
    Quote Originally Posted by Solun Decius View Post
    Ah, nothing says "Christmas" like a huge stick with a nail in it
    Chapter Master Charistoph's Avatar
    East Mesa, Hell (Arizona)
    For an example of the first quoted FAQ, please see the Marine Dreadnought's DCCW.
    Are you a Wolf, a Sheep, or a Hound?
    Quote Originally Posted by Megavolt
    They called me crazy…they called me insane…THEY CALLED ME LOONEY!! and boy, were they right.
    The inclusion of the "co-axial" term in the basic rules is kind of odd. It's not anywhere else, and in fact the last time I remember seeing it was in the Vehicle Design Rules somewhere in 3rd edition (is it in some Apocalypse super-heavy somewhere now?). We assume, and the FAQ confirms, that this is what the "co-axial" term is referring to - the long-extinct special rule from optional rules of two editions past (or at least something I'm unaware of from the extended ruleset).
    I will confess rather more sympathy than usual for the original question. There's no special rule for "turret" yet we all know what a turret-mounted weapon means when the rules refer to one by dint of it being obviously mounted on a turret. In the current edition there's no special rules for co-axial weapons, so why wouldn't a weapon which is, in fact, obviously mounted co-axially, qualify? Precisely because such a rule exists somewhere else, as far as I can tell.
    Quote Originally Posted by DoctorTom View Post
    this is probably the first time in the forum someone had to give a definition for "a". Congratulations.
    Jan 2010
    Quebec
    Thank you for the explanation, Nurgling Chieftain.
    This is why I asked the question, because for me, they are co-axially mounted. As I was not aware of an old rule about coaxial weapons, if it weren't for the SM faq making it clear what is the rule for a las/plas, for me there would not be a definitive answer to that.
    Jan 2011
    Birmingham, UK
    Quote Originally Posted by Charistoph View Post
    The dreadnought's weapons on it's arm are listed as "built-in" - I suspect this will be more clearly defined next edition.
    40k Supplements, Add-Ons & Events:
    [Dyer's Eve - 40k Zombie Apocalypse]
    More Coming Soon
    Quote Originally Posted by A.T.
    Special Rule - My Army
    If there are no units that I don't want to use in the army, the units I want to make more powerful may take what I want to have for free. In addition, everything else gets something else I want free too.
    Chapter Master Seattledv8's Avatar
    Sep 2008
    Wa. state
    FW does have some vehicles with co-axial weapons.
    "Do you use the number on the bottom of the die to determine your rolls? Because the book doesn't discuss that the top is the correct side to read, either. Some things are just THAT obvious."
    destroyed? (p61)
    A: Yes.
    Quote Originally Posted by Chapters Unwritten View Post
    Exactly, and I hope so as well. GW has shown itself to be quite fast and loose with its rules, though, so I don't expect it.
    Honestly, I'd say the dreadnoughts' arm weapons were more clearly defined this edition. While the ruling itself has never changed (if you blow off the DCCW, the storm bolter/heavy flamer has always gone with it), the wording behind it has become much stronger. It's listed as a built-in weapon, and weapon-destroyed says built-in weapons go along with the main weapon. How much clearer can it really get?
    Chapter Master carldooley's Avatar
    NY, USA
    of course, then someone has to mention Manticore missiles. one weapon destroyed result destroys all the remaining missiles - on the turret.
    Quote Originally Posted by Lord Damocles View Post
    Should I find this thread funny or horrific?
    Maybe the hit just disables the targeting mechanisms. Similar amusement with smart missile systems and typhoons, both of which are single multi-shot weapons split on either side of the hull!
    Quote Originally Posted by carldooley View Post
    Not the same case: a manticore launcher is one weapon system with a special rule that allows it to fire only four times per game. It is not four different missiles. Of course one weapon destroyed result will destroy the entire one manticore launcher.
    Awesome. Awesome to the head.
    May 2010
    Everett, WA. USA
    Quote Originally Posted by Seattledv8 View Post
    Does not the Imperial Guard book have some options to co-axially mount stubbers on some tanks?
    You can't spell manslaughter without laughter!
    Chapter Master chromedog's Avatar
    Newcastle, Australia
    No, it doesn't. Just pintle mounts.
    It's only the FW models with co-ax mounts. An Apoc rules where it counts.
    Sent from my Nokia Lumia800 using my microwave as a proxy server.
    That is not dead which can eternal lie
    And yet, with strange aeons, even death may die.
    I am the guy who thought the LoTR movies were crap and liked Judge Dredd.
    DC/MD, USA
    The Baneblade and most of its variants have that co-axial autocannon for their main guns, which allows it to be more accurate for targeting purposes.
    It's listed as "Baneblade cannon with co-axial autocannon". Only the main weapon is listed as Primary Weapon, which gives it that 4+ save. So on a Weapon Destroyed result, can your opponent be cheeky and destroy the autocannon, taking the Baneblade cannon along with it? I don't see any reason why one couldn't destroy the co-axial weapon. Am I correct in this? Due to the wording of the Primary Weapon rules, the Baneblade cannon should still get its 4+ save against being Destroyed but it seems like you could destroy the autocannon no matter what and still get a shot at destroying the Baneblade cannon, whereas if you allocated the Destroyed result to the Baneblade cannon the autocannon would only be affected if the Primary Weapon save was failed.
    Or am I just flat out wrong in thinking that co-axial works both ways?
    Then again, this would be in Apocalypse and if somebody actually tried that in one of my games I'd put the kibosh on it right quick.
    My Chaos Project Log - ride the lightning!
    Aug 2011
    Greece
    Is the main cannon a built-in, combi or co-axial weapon? No. So it doesn't get destroyed along with the co-axial autocannon.
    Ok this last little clash of rule specifics is rather silly. I think it was the SM Dreadnought FAQ that clarified this, but whenever a weapon with a built-in weapon is destroyed, you take the lesser of the two weapons with it. If your opponent, whether by faulty logic or simply friendly game-play, decides to choose the in-built storm-bolter, hvy-flamer, or such, your DCCW stays. In the case of the Main cannon and co-axial autocannon, I would assume the same goes.
