Results 1 to 11 of 11
Thread: Car Body Primers in the U.S. Any good for miniatures?
    Chapter Master Malakai's Avatar
    United States
    Title really says it all. And if they are fine for priming models what brands would you recommend?
    Thanks in advance!
    -Malakai
    You'll never understand how much watching other people's pain gets me off, hearing their screams and knowing that I have the power of a God - Velvet Acid Christ
    Quote Originally Posted by snottlebocket View Post
    Scout
    Harrisburg PA
    I use duplicolor sandable auto primer for mine and never had any issues with details or anything.
    Sent from my DROIDX using Tapatalk 2
    Chapter Master Jericho's Avatar
    Edmonton, Alberta
    Re: Car Body Primers in the U.S. Any good for miniatures?
    Another thumbs up for Duplicolor from me. Used some on my Word Bearers and it's fine.
    Quote Originally Posted by Dr Zoidberg View Post
    Quote Originally Posted by Necr0n View Post
    So can Allies Of Convinience score?
    Only if dinner and the movie were both of a high quality...
    United States
    I had heard that FW actually recommends using car primer on their resin models. Is this true?
    -Malakai
    Marine
    May 2012
    Northants, UK
    No idea about GW kits, but my step dad uses car primer and proper paint when he builds kits from other manufacturers. So, it definitely works well, we've never had any problems with it.
    Edmonton, Alberta
    That comment about FW recommending it has been around for ages, I'm not sure if it's canon or just some anecdotal evidence of some FW staff preferring car primer. Either way, my most recent batch of FW minis haven't had any issues of mold release messing up the two primers I've used on them (GW and Duplicolor). Even the couple that I forgot to wash first are peachy (but I still highly recommend a wash in the warm soapy goodness!).
    Librarian Sean_OBrien's Avatar
    Apr 2012
    Margaritaville
    Car primers tend to be more aggressive than your regular consumer primers, so they will cut through any oils and release compounds that are on resin models (less effective against release powders though).
    Duplicolor is a good one, which you can normally find at your local big box stores. Others you will want to read the package closely as some of them have fillers to help cover pin holes in the car. On large surfaces, that is a good thing - but one that I used years ago covered up a lot of the detail.
    Disgraced Inquisitor Captain Brown's Avatar
    Vancouver, B.C. Canada
    I use them on my resin models...just one word of warning and advice. Car primer is intended to smooth over cracks and blemishes...so use one or several thin coats rather than a thick covering...otherwise you will see it fill in the model's detail.
    My two cents,
    CB
    Disavowed Moderator...I can only move threads in MP&T and Project Logs now...I cannot revoke your warnings or give access to the Chaos Wastes.
    Elysian Army PLOG - Tau Army PLOG - Ork Army PLOG - Sisters of Battle PLOG - Necromunda Imperial Guard Army PLOG
    Please follow the rules and respect the opinions of others - Warseer FAQ
    Presently selling lots of IG bits - come see here
    Krylon Grey or Ruddy Brown primers are really great. The Ruddy Brown makes a really good base for dark reds.
    Another good primer is the Krylon Ultra Flat Camo spray paints. They are formulated for plastics, dry EXCEPTIONALLY smooth and flat, and the colors are really good, being black, dark brown, forest green, olive drab, and khaki.
    Chapter Master Orcdom's Avatar
    West Virginia, USA
    i vote krylon too its what ive used for years but i suggest swapping out the fan spray tip from another spray can, i dont like it one bit but love the paint.
    i use the white sandable primer and a basic flat black
    Steve
    Chapter Master Spacker's Avatar
    Birmingham, UK
    Quote Originally Posted by Jericho View Post
    There's a PDF on the FW site covering this at http://www.forgeworld.co.uk/Download.../resintips.pdf
    We recommend priming your model with a fine matt car body primer, such as can be found in most hardware stores.
    Dan
    Age of Strife Owner | AB40k admin/beta tester
    Gaming Figures Store Owner | #warhammer40k on irc.quakenet.org Owner
    Quote Originally Posted by Hugh G. Reckshun View Post
    Word on the street is .. if Spacker hasn't said it .. it can't be true. that or .. it's not worth hearing .. one of the two.
