Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 73
Thread: Corner an Abom
    Corner an Abom
    So player A has an HPA and everyone knows it has random movement. Player B has a fast calvery unit that can free reform. So what if the Fast cav move up to it exactly 1 inch away exactly parallel to it. This would technically make the HPA unable to turn at all and be forced to move straight forward the whole game correct? Reason being is when the HPA moves it could never pivot on the spot without getting within 1 inch of the fast cav unit, thus making it go only direclty forward. Looks like this would work to me as long as the fast cav were able to keep up and it didnt get killed by magic or shooting. What do you think?
    Chapter Master theunwantedbeing's Avatar
    Preston,in my house.
    Re: Corner an Abom
    It works on units that don't move via Random movement special rules.
    Plan B kill it with fire
    Meat is Murder tasty, tasty murder
    Quote Originally Posted by RanaldLoec View Post
    I would have to agree with The Unwantedbeing as he is a paragon of sense and reason in an unreasonable environment.
    It would work on me: I would pick up my stuff and head in a straight line to the door, never pivoting for one moment.
    Commander Agoz's Avatar
    Utah
    Re: Corner an Abom
    Quote Originally Posted by LiddellHart View Post
    Ditto, it isn't a tactic, its a loophole.
    Armies I play:
    Ogre kingdoms
    Zombie pirates
    Skaven
    Slayers
    Re: Corner an Abom
    If you brought a single Hell pit maybe, but if you bring two or three you're asking for something like this.
    Thousand Sons/Daemons of Tzeentch/Vampire Counts
    There is a way through the coming darkness. But to find it we must change.
    We must change and change until Change is our master, for nothing neither god nor mortal can hold that which has no form. Change is the constant that cannot be changed.
    Re: Corner an Abom
    Well, rules are rules. I'll be using this tactic at my game store as I have no remorse for skaven. Just thought I would share with others, especially if they hate seeing HPA's on the table.
    Chapter Master RanaldLoec's Avatar
    Nov 2009
    Huddersfield, West Yorkshire, UK ( Land of sheep and cheap ale )
    Re: Corner an Abom
    Please use it in context.
    In a no holds barred tournament by all means fill your boots.
    In a pick up "friendly" game only try it if your not too bothered about playing your opponent again or about gaining a reputation.
    80 imperial guard stormtroopers for sale
    11 chaos dwarf bull centaurs for sale
    8 dragon ogres white metal for sale
    All in the thread below
    http://www.warseer.com/forums/showth...48#post6716248
    Chapter Master Lord Inquisitor's Avatar
    Norfolk, VA, USA
    Re: Corner an Abom
    As theunwantedbeing pointed out in the first reply, it won't work against HPAs. As they're random movement, they're allowed to move within an inch when moving (or they'd never be able to charge anything!*), so the HPA will simply pivot into contact with your unit and close the door.
    Against other units it can work to some degree. Particularly very long units like Bret cav buses can be vulnerable to being "pinned" but the utility is rare. Typically you'll require two units, but a couple of units of furies or harpies one on each side can really squirrel up such long units in certain specific circumstances.
    *This isn't explicit in the rules but is implicit, unless you want to argue that random movement units can't charge anything, ever.
    ... and then I won.
    Re: Corner an Abom
    They way I understand it is that if random move would bring you into contact with enemey then it counts as charging through normal charge rules. So if a unit is directly parallel to the flank of a HPA facing it and say just a little back what would end up happening is you would charge the flank of the HPA in to the front of said unit. Under normal charging rules you cant charge your flank into a unit? Correct? Sounds funky, I'll just have to talk with my local game group about this.
    Chapter Master T10's Avatar
    The Danger Zone!
    Re: Corner an Abom
    Perhaps it would have been best if all single-model units with the Random Movement special rule used circular bases.
    -T10
    Will Orc for food!
    Chapter Master hazmiter's Avatar
    Jan 2012
    Australia, N.S.W
    Re: Corner an Abom
    I for one will not use said tactic, unless forces to, it seems like it ties too much up in one place, and leaves you open to nasty stuff.
    Bring out sword of rhuin and xbows......
    Warhammer 6th edition.
    Grey knights: wins:8 draws:1 losses:1.
    Blood angels: wins:2 draws:0 losses:1.
    New projects: dark elves, cygnar, blood angels (brotherhood of blood)
    Chapter Master Satan's Avatar
    Denmark/Sweden
    Re: Corner an Abom
    Quote Originally Posted by T10 View Post
    Perhaps it would have been best if they just rewrote the Random Movement special rule.
    -T10
    I agree completely.
    Plog of Jericho - Wood Elves, Daemons, Beastmen, CSM and Whatnot.
    MD: You got a christmas gift?
    House: Yeah, 'cause I worship Santa. Or wait, is that Satan? I always get them mixed up.
    Re: Corner an Abom
    Please read the random movement rule. "If a model comes in contact with the enemy, it counts as having charged."
    So if he starts to turn and comes in contact with you, then he counts as charging.
    However, this trick might work if you could stay one inch away from him and with his random roll manages to not make contact - Maybe by using some sort of fifth dimensional physics - Then he wouldn't be able to charge you.
    However, if you were within his random movement distance, he hits you.
    Jan 2012
    Australia, N.S.W
    Re: Corner an Abom
    The pivot happens before the roll though.
    Rule stipulation is 1 inch between you, and opponent, this goes for trying to charge "squeeze" warsphinxes through a 2" gap.......
    Re: Corner an Abom
    Doesn't matter when the pivot happens. It's a separate sentence. If someone is going to be ******* and pull a move like this, then I'm going strictly by the wording. In this case, a sentence that could have nothing to do with the previous sentence about rolling. In fact, depending on how ******* they got, I might accidentally tip over my model and then point out that he counts as charging whatever he accidentally touched. Or lay down a marker to show where the model is supposed to be on the table, then pick it up and randomly walk over and tap models on the opponents side and claim I charged them as per the rule.
    Jan 2012
    Australia, N.S.W
    Re: Corner an Abom
    I see your point memnos, and it is a below the belt cheap shot to use that tactic, I've done quad hydra at 4k points, that was nasty.
    Re: Corner an Abom
    Skaven have so many chaff and redirectors not to mention guns and direct damage, it would only work on the most beginner of players, IF it worked. Stick to flaming attacks to kill Aboms.
    Re: Corner an Abom
    The last time I played a 3 Abom list with my Beastmen, I killed 4 Abominations.
    One got back up.
    Throwing out massive damage to break monsters using any army isn't that hard. You don't have to resort to clearly shifty rules interpretations to kill them.
    Limerick
    Re: Corner an Abom
    How on earth do people see this as a loophole? The 1" rule and reform/pivoting rules as well as random movement are all clearly laid out with no ambiguity and this is a clearly forseeable circumstance of those rules' combination. There is no amount of lawyering or explaining needed here so I fail to see how it is a loophole. I also find it amusing that people laying Aboms are complaining that there is a counter to them.
    Re: Corner an Abom
    Interesting scenario. Unfortunately the HPA's forward arc is determined after it pivots or the random move rules wouldn't work at all since it tells you to measure the distance of the dice rolls(which is after the pivot) to determine if it meets its charge range. It can just turn a little bit, move forward half a inch and clip your fast cav, then you'll have to deal with the D6 impact hits which will probably cost you the combat.
