Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 21 to 40 of 130
Thread: Post youre Fleet(s)
    Re: Post youre Fleet(s)
    we agreed we would use book of nemesis amongst ourselves so the officialness isnt really a problem.
    been without the internet for quite a while so kindve missed the 2010faq, knew about it but didnt have a copy. just downloaded it and will give it a read. maybe any ships i like will be added to the battle fleet.
    what do people think of my battle fleet regarding the balance of battle ships/cruisers/escorts etc, the other half has pretty much the same balance, should we have more escorts or more battle ships etc what do people think a sectors battle fleet would contain?
    regarding the oppressor, how much should an upgrade of lances to 45cm from 30cm cost? i figured if its 10 points to upgrade fp 6 30 cm wb to 45cm then lances being more effective at range deserved around an extra 5 points to make 15? should i go with 20 points?
    the centurion ship is built with 3 lances because it looked cool, hadnt really thought about the crippled/brace thing, will probably put in its rules that it goes down to 1 rather than 2 if i go with the long range variant or leave it at only going down to 2 if i go with the 30cm version, the rules are still up in the air at the moment.
    thanks for the input, much appreciated
    Got pics of my marine mini-fleet up now:
    http://epicaddiction.wordpress.com/bfg-marines/
    My EPIC and BFG Blog: EPIC ADDICTION
    Chapter Master horizon's Avatar
    Quote Originally Posted by Radu Lykan View Post
    The Tyrant is +10 pts for upgrading str8 wb from 30-45cm
    At 30cm 1 lance = 3 wb. So you're 4 lance equals 12wb @ 30cm. So +4wb to the Tyrants 8wb = +10+5 = +15pts
    So far correct. However: above 30cm lances become more valuable then wb's as latter have a right shift. I would value this at +5pts.
    So in total the cost would be +20pts for the lances to see their ranges upgraded.
    If you word it nicely go with it
    No problem.
    WARP RIFT - The Battlefleet Gothic online fanzine.
    Available for download here:
    http://www.tacticalwargames.net/arch...mag/index.html
    GothiComp Hall of Fame
    Horizon's New Blog
    i might be being stupid but when does a tyrant have str8 wb? it upgrades its str6 wb to 45cm making it str10 at 45cm.
    my reasoning is to upgrade a str6 wb from 30cm to 45cm costs 10 points.
    at 30cm str6 wb = 2 lances
    add 10 points to upgrade to 45cm
    then i added half the upgrade again due to lances>wb at ranges over 30cm
    is the upgrade from 30cm to 45cm for lances really worth double the upgrade of equivalent weapons batteries? i have no problem paying the points if they are, i am simply confused by the above post
    thanks again, sorry if i seem ungrateful, i am just dumb
    Feb 2012
    I dont think you should compare that ship with the tyrant. Its a diffrent situation. 15 Points seem ok to me. Even tho I doubt I would use this model in a fleet because for me it would be to expensive for a cruiser.
    Oppressor is fine at 235 your paying 15 points to upgrade one hardpoint which only costs 10 points for weapons batteries. Given that its a pretty pointless upgrade on a ship you want to close with inorder to take advantage of the torp/ac synergy id say 15 points is even pushing too much.
    As for Dr Frankenstines 3 lance ship i think i would run it as an early battlecruiser prototype trying to build off the older grand cruisers. Keep the stats as is 220 points 1 per 2 cruisers and no funny math when crippled.
    Yes, it should be measured with the Tyrant. You look into the Imperial Fleet asset and need to balance it.
    @ Radu,
    no worries
    The Tyrant does not have str8wb but it can upgrade 8 of its 30cm weapon batteries to 45cm. (4 per side). After the upgrade it has 20wb @ 45 in total, 10 per side.
    ' kay.
    So we can upgrade 8weapon batteries on the Tyrant from 30cm to 45cm for 10pts.
    Your ship has 2 lances per side is 4 in total at 30cm
    In wb this would equal 4lances x3 = 12 weapon batteries
    Now you want to extend range as well:
    If 8 wb = +10pts to do so then 12wb = 150% of 8wb = +15pts (10 + 5 additional)
    Then we add in the effect that lances are more worth then 3wb at 45cm* due the fact they have no right shift they should pay a little more -> +5pts
    5pts + 15pts = 20pts extra for the range upgrade of the lances.
    @ 30cm 1 lance = 3 weapon batteries
    @ 45cm 1 lance > 3 weapon batteries
    Horizon's New Blog
    sorry to be a pain but i have reworked your post armed with the fact that the upgrade that costs 10 points on a tyrant is for upgrading str6 batteries not str4.
    Quote Originally Posted by horizon View Post
    @ Radu,
    no worries
    The Tyrant does not have str8wb but it can upgrade 12 of its 30cm weapon batteries to 45cm. (6 per side). After the upgrade it has 20wb @ 45 in total, 10 per side.
    ' kay.
    So we can upgrade 12 weapon batteries on the Tyrant from 30cm to 45cm for 10pts.
    If 12 wb = +10pts to do so then 12wb = 100% of 12wb = +10pts (10)
    5pts + 10pts = 15pts extra for the range upgrade of the lances.
    if it was str4 then i could see where you are coming from and see where the confusion/disagreement arises. do you follow my reasoning and accept 15points? as i say i am not too bothered about the points value of the ship but do want it to be priced consistantly. hopefully thats all sorted now
    andrewchristlieb
    if i go down that route i would need to add cruisers to my fleet as currently there are just enough cruisers to allow the battle cruisers. i might go with only 1 Dr. F's centurion per fleet rather than any other limits. i am fine with down grading it to 1 lance when halved as a weakness, i dont want it to look like its designed to bend or get around rules to give an unfair advantage. thanks for an idea of the pricing, as i havent finalised the rules i havent really considered the points yet.
    right, sorry for hijacking the thread, on with the fleet pics everyone!
    haha, lol Facepalm.
    Even veterans need to look things up.
    You are correct, it is 6wb that goes from 30 to 45 on the Tyrant.
    Ya, 15pts is thus sensible.
    Horizon's New Blog
    Chapter Master Ragsta's Avatar
    Edinburgh
    Some really good fleets here! I do so love Battlefleet Gothic
    Here are some pictures of my old Imperial fleet - since these were taken I have repainted them and bulked them out rather substantially
Name:	Battlegroup Resurgent.JPG
Name:	Shark Squadron.JPG
Name:	Strikeforce Ephialtes.JPG
    So yes, I used escort ships from GZG and some OLD school escorts that I got off eBay to give them some originality. I fanyone is interested I will post up my new style fleet at some point.
    Keep posting your fleets everyone!
    P.S. How the flip do you post the actual pictures rather than attachments? It keeps coming back with an error
    Imperial and Ork starships, random Imperial troops and now the developing zombie plague...
    Building the Orkmada- BFG Orks
    :skull: World War Z :skull:
    Quote Originally Posted by GomezAddams
    Right I'm going to head off, got cowgirls with massive racks to paint - its a hard life
    It's a shame nobody has posted pictures of their Tyranid fleet yet, I'm always thirsty for some conversion inspiration and the like.
    Chaplain afterimagedan's Avatar
    May 2010
    Chicago IL, USA
    Quote Originally Posted by fondfarewell View Post
    Here's my Tyranid fleet:
Name:	Tyranid Hive Fleet.JPG
    Here's some of the fleet in the first paint scheme.
Name:	Tyranid Claw Kraken.jpg
    Here's how I do it:
    http://youtu.be/n0epmk_4M3s
    Feb 2012
    Quote Originally Posted by Jihad_Ragsta View Post
    Lol.. are that little Plastik-Cars as Ship prows ???
    Edinburgh
    Quote Originally Posted by Vanquisher View Post
    Goddammit I can never get away with that scratch build piece!! Yep, it's a toy car from the 'Life' board game
    Feb 2012
    Yea and the Holes are for the blue and pink pins I remember that. But nice paintjob.
    Chaplain Jakeman214's Avatar
    Nov 2011
    Cloud Cuckoo Land!
    I've got 4,500 of Imperial Navy, running as a Bastion Fleet. It just keeps growing somehow, from a 1500pt cruiser gunline into a small Sector Battlefleet with 37 ships on the roster ranging from a Battleship right down to little escort carriers.
    I also have around 1500pts of Orks that need basing because I am lazy. They only really get to play when I am up against another ordnance heavy fleet (Terror Ships + Gorbag's Revenge = Fighta-bomma heaven!).
    Father Mulcahy: Just as the Lord said to Noah, "Everything in pairs."
    Pierce Hawkeye: Of course the Lord was holding three aces at the time.
    Scout
    Mar 2012
    Sheffield UK
    Ive got:
    Space Marine
    1 Battlebarge
    3 Strike Cruisers
    3 Hunters
    3 Glads
    3 Novas
    Imperial
    Mars
    Lunar
    Gothic
    3 Firestorms
    Chaos
    1 Despoiler
    1 Repulsive
    1 Styx
    1 Murder
    1 Slaughter
    Eldar
    Void Stalker
    2 Shadows
    2 Eclipse
    2 Solaris
    2 Aurora
    9 Hemlocks
    I am planning on improving my Chaos and Imperial lists.
    Nov 2011
    Cloud Cuckoo Land!
    Hmm, I'm bored so I might throw up the fleet compositions.
    Battlefleet Sapphira, Imperial Navy
    1 Victory Class Battleship
    2 Vengeance Class Grand Cruisers
    1 Executor Class Grand Cruiser
    2 Mars Class Battlecruisers
    2 Dominator Class Cruisers
    2 Gothic Class Cruisers
    2 Lunar Class Cruisers
    2 Murder Class Cruisers
    2 Dauntless Class Light Cruisers
    6 Sword Class Frigates
    6 Firestorm Class Frigates
    5 Cobra Class Destroyers
    4 Escort Carriers
    With the veteran captains of the bastion list added in, around 4,500pts.
    Orks
    1 Gorbag's Revenge Battleship
    4 Terror Ships
    2 Kill Kroozers
    8 Escorts (they change class constantly...)
    After Warlords and upgrades it's around 2,000pts I think?
    Cool then, I'll add my register:
    Tau
    Tau Commerce Protection Fleet - Dal'yth
    Ry’zon - Kor’o
    Am’eru - Aun’o [deceased]
    Custodian Class Battleship - Or’Es’Leath Ry’zon
    Protector Class Cruiser - Lar’shi’vre Ry’zon Ni
    Protector Class Cruiser - Lar’shi’vre Jate’ra K’ri
    Protector Class Cruiser - Lar’shi’vre L’kys
    Emissary Class Cruiser - Porr’ui I’chne
    Emissary Class Cruiser - Porr’ui Wi’hs
    7 Castellan Class Frigates [7] - Ka’Eldi
    5 Warden Class Destroyers [5] - Shas’ka Nan
    Tau Special Strike Force L’or’ang’
    Castellan Class Frigates [3] - Ka’Eldi
    Tau ECF reserve
    Explorer Class Battleship - Gal ‘leath
    Renegade Fleet [Chaos]
    Admiral - Khurzon Reznard
    Desolator Class Battleship - Frozen Sun
    Repulsive Class Grand Cruiser - Heart of Darell
    Styx Class Cruiser - Divine Messenger
    Carnage Class Cruiser - Last Hope
    Carnage Class Cruiser - Saint Leroux
    Slaughter Class Cruiser - Da’rell’s Wrath
    Infidel Class Frigates [3] - Vengeance
    Infidel Class Frigates [3] - Fallen Grace
    Iconoclast Class Destroyers [3] - Hunters of Da’rell
    Eldar
    Corsair Eldar Fleet – MMS
    Hero - Akaeris Starblade
    Void Dragon Class Cruiser - Spirit of Arina
    Void Stalker Class Battleship - The Silent Enigma
    Eclipse Class Cruiser - Shroud of Frost
    Aurora Class Light Cruiser - Karan Jain
    Solaris Class Light Cruiser - Dras Sha’eil
    Hemlock Class Destroyers [3] - Oriosa Novar
    Nightshade Class Destroyers [2] Aconite Class Frigate [1] - Arith Kian
    Aconite [1] Hemlock [1] Nightshade [1] - Sier Shemas
    Nightshade Class Destroyers [3] - Bennan Baharr
    Hemlock Class Destroyers [2] Aconite Class Frigate [1] - Karun Lir
    Craftworld Eldar Fleet
    High Admiral Akaeris Starblade
    Dragonship Class Cruiser - Cerysheal
    Dragonship Class Cruiser - After Forever
    Wraithship Class Cruiser - Destiny
    Wraithship Class Cruiser - Infinity
    Wraithship Class Cruiser - Eternity
    Spacefleet Wraithship [Ghost] - Varjo Aave
    Spacefleet Wraithship [Ghost] - Ar Liru
    Shadowhunter Class Escorts [4] - Starspeed
    Spacefleet Shadowhunters [2] - Twilight Moon
    Chaos Fleet
    Warmaster Amon Dn
    Despoiler Class Battleship - Dark Treachery
    Acheron Class Cruiser - Chaos Eternus
    Devestation Class Cruiser -
    Murder Class Cruiser - Rotblut
    Slaughter Class Cruiser - Count Larchavre
    Idolater Class Frigates [4] - Piercing Pain
    Iconoclaust Class Destroyers [3] - Deathskill I
    Adeptus Mechanicus
    Explorator - Inachus Tynton
    Retribution Class Battleship - Judgement Forge
    Lunar Class Cruiser - Quest Mechanicus
    Gothic Class Cruiser - Divinus Mechanicus
    Endeavour Class Light Cruiser - Calvinus Rekat
    Gladius Class Frigate [3] - Curator Mechanicus I
    Hunter Class Destroyer [3] - Curator Mechanicus II
    Space Marines
    Master of the Fleet - Veliaz
    Space Marine Venerable Battle Barge - Horizon’s Edge
    Space Marine (Novamarines) Scout Cruiser - Daedalus
    Space Marine RSV Firestorm Class Frigates [2] - Xxxxxxxx
    Imperial Navy
    Fleet Admiral Admiral Gravenstein
    Apocalypse class battleship - Astrum Terra
    Lunar class cruiser - Commissar Vandemarr
    Lunar class cruiser - Praetor Maximus
    Dictator class cruiser - Acheilos
    Dominator class cruiser - Imperator
    Sword class frigates [2] Firestorm class frigate [1] - Fury
    Cobra class destroyers [3] - Enyo
    Cobra class destroyers [3] - Deino
    Rogue Trader
    to be sorted:
    Rogue Trader Cruiser, Endeavour Light Cruiser, various xenos, recommissioned, transports, etc
    Dark Eldar - to be painted
    Archon
    Torture Class Cruiser -
    Corsair Frigates [3] –
    Corsair Frigates [3] -
    Tyranid Vanguead
    18 escorts to be sorted
    Necron
    Tombship - Imperial Designation: "DeathScythe" // re: Tombship // re: Necron
    Ork
    Terror Kroozer - HacknSlash
    Horizon's New Blog
    Nov 2011
    Cloud Cuckoo Land!
    Dammit Horizon, stop putting us all to shame!
