Results 1 to 13 of 13
Thread: Demiurg using Kharadron Overlords.
    Commander Inso's Avatar
    To cut a long story short... I quite liked the idea of rock-dwarfs in space so I decided to put some together. I used some bits from various companies and based the troops around GW Kharadron Overlords with converted heads.
    These three are the first of the troopers:
    They represent (bottom row from left to right) a drone controller, leader and mech. After a little bit of negative feedback, the leader got a trim:
    The idea is that each unit has the three troopers above in it and is accompanied by a range of drones; both ground and air based. The first drones are these:
    I need to re-base them to match the Demiurg but they are painted and in storage somewhere so I will have to dig them out, at some point, to do it. I also need to tidy up the base of the drone controller that is posted below (the first one of the Demiurg that I have painted):
    The next one to be painted will be the mech.
    Another day older; another day closer to the grave.
    I have a blog here: http://insosworld.blogspot.com/
    and a Grymn blog here: http://grymnoutthere.blogspot.com/
    Chapter Master Lost Egg's Avatar
    Wandering in the wilderness...
    Re: Demiurg using Kharadron Overlords.
    Great work Inso, it's good to see you have returned to this project
    I'm digging th controllers paint scheme and his face, he definitely doesn't look like a Kharadon anymore.
    That's the controller and the mech done now... next up is the leader (which is already started ).
    So... in a moment of drug induced (prescribed painkillers) euphoria, I went online and did some shopping and for some reason, I bought a radio controlled truck. It was cheap (luckily) but it is large and has six wheels.
    I have no idea why I decided to buy the thing but, in hind-sight, it probably wasn't such a bad idea. I can turn it into a Demiurg super-heavy transport .
    The truck is the one on the left and the image on the right is of the shape I quite like... but obviously, the vehicle will be MUCH larger . I reckon I can turn it into something quite interesting... with the added bonus that it will be able to move around under its own steam :
    Sounds a little bit mad I look forward to seeing what you do with it!
    I have now finished the third Demiurg (the leader):
    I have also started work on the army commander:
    I like the way this is going
    Inquisitor Captain Brown's Avatar
    Vancouver, B.C. Canada
    Inso,
    Most impressive converting. Those Demiurg are some of the best I have seen.
    CB
    Welcome back everyone. Please check your old PLOGs and update photos that have been lost in the hack or Photobucket block.
    Elysian Army PLOG - Tau Army PLOG - Ork Army PLOG - Sisters of Battle PLOG - Necromunda Imperial Guard Army PLOG - Alaitoc Eldar PLOG
    Please follow the rules and respect the opinions of others - Warseer FAQ
    Selling OOP GW Books and Games - Interested in buying oop metal Eldar
    I did a bit of rooting about in storage boxes and have located the drones that I have assembled. 3 just need the bases doing and the other 3 need a lot more work. I have also started the three Demiurg troops for the next unit :
    I thought I may as well get on with the next 3 Demiurg, seeing as I am sculpting heads for the commander and his driver already... may as well do them all
    That's shaping up to be a cool looking force.
    Cheers . The good thing is that the drones aren't converted and it's just a case of assembling and painting them... which makes a change from my usual army building routine. There's also a bit of decent variety between the models so it should keep me entertained a bit.
    The first three drones are now re-based and have joined their Demiurg owners:
    I think that each of the drone squads will have six of these large drones in them, with a few aerial drones for spotting and shielding. I haven't decided on which aerial drones I will go for yet... so I will tick along with the big drones and Demiurg for now .
    Chapter Master Karak Norn Clansman's Avatar
    Karak Norn
    You've actually sculpted Demiurg heads for them! Quite ingenious project, endowed with vision. It looks good so far. Keep it up!
