Results 1 to 13 of 13
Thread: transfer help!!
    Commander Lavadude360's Avatar
    Niether here nor there
    Exclamation transfer help!!
    Space marine shoulder guards are IMPOSSIBLE to get transfers to sit neatly on!!!
    If anyone can help me get them to sit right I'll give them not 1 not 2 but 12000 cookies!
    Please help me!
    Chapter Master schoolcormorant's Avatar
    Tynemouth UK
    Re: transfer help!!
    micro-sol and micro-set.
    if you can't get that, you can cut nicks around the transfer, very thin ones when you position them, this sort of compensates for the uneven surface and should help.
    SC
    Quote Originally Posted by Hideous Loon View Post
    Listen to schoolcormorant, for he is wise.
    Quote Originally Posted by Captain Cortez View Post
    For a brit. you got some bad gramer.
    Chapter Master time wizard's Avatar
    New York, USA
    Re: transfer help!!
    First you have to trim the transfer. Cut away any part that does not have the image on it. If you look at the transfer you will see an area of clear film around the image.
    After you get the transfer on the model, blot off any water. Then apply a drop or so of a decal softening solution (I use a product call solvaset, I'm in the USA, don't know if it is available everywhere). Then let the model sit until the solvaset dries. This should soften the decal and allow it to form on the pad.
    I have found again and again that in encounter actions, the day goes to the side that is the first to plaster its opponent with fire. The man who lies low and awaits developments usually comes off second best. - Erwin Rommel
    Quote Originally Posted by Murphy's law View Post
    Listen to the wizzard!
    This is pure logic.
    Banned Bregalad's Avatar
    Sa'cea
    Re: transfer help!!
    You usually get micro-sol or micro-set in model railroad stores or mail order shops (like Walther's).
    Re: transfer help!!
    thanks guys that is really helpful coz there isn't a tut in the 'how to' section.
    Re: transfer help!!
    Forgive me for necro'ing.
    I'm pretty new to converting and painting in general, but I was frustrated with the decals as well. I cut slits in my Templar decals to help them lay flat, and then held the model about 4-5 inches over a candle. It caused the decal to go all shrinky dink and conform to the pad in the areas that, previously, would not lay flat. Has anyone else tried this?
    Re: transfer help!!
    is there any other way apart from "decal-softener".........................
    Librarian USABOB's Avatar
    Hard to Spell, Easy to Draw
    Re: transfer help!!
    Quote Originally Posted by GTARob View Post
    I guess yes : )
    I have a rather unorthodox way of applying transfers. I put the transfer in the correct place (after the water phase) and give it a burn with a cigarette lighter (light it and immediately let it shut off letting the flame touch it no more than quarter second, may need to be done more than once to get the edges you missed). I suggest you experiment on an unfinished project first, if done right the transfer appears painted on and the gloss is significantly reduced. That method works for me and didn't require me to buy decal softner, which made it more appealing and doesn't burn it up like a constant flame .
    I reject your reality and substitute my own.
    Visit my Warseer Gallery
    My Photobucket page with my scratchbuilt Ultramarines Thunderhawk.
    Tutorial on making plastic Grey Knight style terminator helmets, storm bolter arms, and halberds.
    Re: transfer help!!
    it works! my thanks to you sir
    Re: transfer help!!
    You can use plain white vinegar in the place of the expensive decal softeners.
    Big Scary Robot Wintermute's Avatar
    Lurking in the dark... in the void between worlds....
    Re: transfer help!!
    Quote Originally Posted by xrey View Post
    No there isn't.
    BTW in addition to decal solvents, you need to put a coat of gloss or satin varnish on the area where the decal is to be placed, and then another coat after the decal (using solvent) has been placed. You can then add a coat of matt varnish if you want a non-shiny finish
    Quote Originally Posted by philbrad
    As ever WINTERMUTE speaks the truth
    RIP Jon Wilson/Brimstone. 1967-2009.
    If you can please donate to The Jon Wilson Gift of Hope Heart Fund in aid of the British Heart Foundation
    Lee Guthrie/Eldanar RIP
    Chapter Master Vermin-thing's Avatar
    In your kript, waiting for FEB, and Beastmen!!
    Re: transfer help!!
    I tried to apply some via the instructions on the back of the sheet, but alas they all fell of.
    Anyways I found a article on applying transfers on the GW site.
    Linky >>> http://www.games-workshop.com/gws/co...03&aId=2600032
    Rumours of rumours??? thats warseer
    "I could have died"! "Looks like you lost this game in the "purchase models" phase."
    Armies that are done: 2k high elves Armies in progress: Skaven, Vampire Counts
    "Alright, your vampire just died. Roll for crumble." "...hah! You've fallen into my trap!..."
    My Eshin spies prevail again.
    Brother Sergeant Corvus's Avatar
    Sep 2008
    Antwerp, Belgium
    Re: transfer help!!
    There are two alternatives:
    1) use a hairdryer: be careful not to melt plastic models! Just give it a few seconds.
    2) use vinegar (haven't tried this): it's the main ingredient of commercial decal softeners
    But if you have access to Micro-Sol or something similar I'd advice to get a bottle of this: it's cheap and will last for hundreds of decals.
  1. Transfer symbols
    By Kromando33 in forum Warhammer 40,000 General Discussion
    Last Post: 11-10-2006, 11:01
  2. transfer question
    By x-esiv-4c in forum Warhammer 40,000 General Discussion
    Last Post: 31-07-2006, 20:11
  3. Printable Decal (Transfer) Paper
    By Heru Talon in forum M, P&T General Discussion
    Last Post: 11-05-2006, 17:05
  4. VHS - DVD data transfer recorder.
    By Mad Doc Grotsnik in forum Random Musings
    Last Post: 11-01-2006, 09:48
  5. transfer shine
    By blue midgets of doom in forum M, P&T General Discussion
    Last Post: 01-09-2005, 07:17
