N810: Thank you very much. It seemed to drag on a bit but once I got stuck into it I really enjoyed myself. I've been hesitant trying to build my own terrain. Fear of failure and all that. I'm glad I persevered with it. More will follow.
Tzarinchilla: I've seen pictures of your board and it looks great. I like the erosion where the grass gets close to the rocks. Doesn't look like my board but they are different landscape I guess. I think if I hadn't have seen the 3T-Studios one I may have gone for something more akin to yours. Glad you like my efforts. You can still see the polystyrene, but I think it's about disguising enough of it so you go with the illusion. Cheers!
I've been determined to get my Tale of Terrain entry in on time so I've spent the last few days working on three craters and some homemade walls:
The pictures above show the craters with spots of sand and pea gravel. I trimmed off the excess plastic around the edges BEFORE adding texture this time around: MUCH easier.
I began working on the walls by trimming off the excess card around the edges so that it sits properly on my knobbly board. The walls themselves are packaging made from a kind of moulded cardboard/papier mache. Again, I got these from work.
I then coated the walls with a layer of sand stuck down with PVA. Then I cut some pieces from sheets of textured plasticard and gave them "damage". These were then stuck to the walls with plastic glue. I then added more sand to the bottom of the pasticard bits to blend them in more with the walls:
While the walls were drying I painted the craters. These are the three remaining ones from the pack of five. With these I wanted to make them look more "fresh" and so lightened the crater interior. The rest was done pretty much the same as the last lot but I spent less time highlighting the rocks:
Everybody knows that craters are best photographed in the kitchen, yeah?
More to follow......
