Results 1 to 15 of 15
Thread: Building Yss: DC's Terrain Project Log.
    Mors Cattus Moderatus DeathCat147's Avatar
    That dark place inside you......
    Building Yss
    I felt it was time to build a new gaming board that could be used for AoS (and occasionally for Historicals). I've spent about six or so months looking up youtube tutorials and educating myself on various techniques and materials in preperation for the big build.
    Board wise I contemplated a number of options and their pro's and cons, before settling on a modular system which I could add scatter terrain to. In the end I went for Sally 4th's Terra-Former Tiles, a well rounded range of MDF frames with a magnetic locking system. The frames themselves are well designed and do pretty much what they say on the site. The neodynium magnets really lock them together really well and the frames are nice and sturdy. I used superglue to put mine together for speed and efficiency, but woodglue would be perfect if drying times aren't an issue for you.
    The frames require some form of polystyrene filler, either the simple jablite stuff or the lovely pink insulation foam. I went with jablite for affordabilities sake and ease of access. While jablite isn't my first choice for terrain building it is fine for this, as it will be covered up with filler and pva to strengthen it. To save time I whipped up a template to help with cutting out the inserts. Having to hand measure each one prior to cutting would have been labourious and tedious. With the template it was barely a twenty minute job to cut all of them out and fit them. Make sure you use a nice sharp blade to cut them, I used a snap off knife with the blade extended all the way to cut mine clean through.
    Then it was a case of gluing and adding detail. The cliff faces are made from discarded slate shards I found in the fathers hoarded building material pile. I just stacked them up and glued them in place. I used PVA which I regretted, as it didn't really stick them down all too well, it was the filler that really secured them in place. Next time I'll use the hot glue gun.
    Then it was on to adding filler. I used plain old polyfiller. I did start putting it on with a spatula, but it started looking unnatural, so I slipped on some gloves and applied it by hand. It's helped maintain a natural look and allowed me to get the filler into all the nooks and crannies around the cliffs and into the stream bed.
    Once dry, I added some citadel trees and textured the board with coarse and light sand, along with aquarium gravel for smaller rocks. The larger rocks were either slate or decorative garden stones. When applying the sand I used a watered down mix of pva with a little flow aid added.
    Then I painted it all. A black undercoat on everything, with some zenithal highlights of a medium grey on the trees, cliffs, and rocks, along with some splashes on the dirt. Then I added a chocolate brown emulsion, and once dried I used a large make up powder brush to drybrush the whole board with Buff Titanium from Daler Rowney. It took about thirty minutes to drybrush the whole board. I'll be buying more make up brushes from mini painting after seeing how effective it was, after a quick wash it was good as new with zero wear. If I had used my usual choice it would have killed the brush and only been good for rubbish jobs after.
    Flocking was fairly easy, I used the same watered down pva mix with flow aid to spritz the sections. Then I went along the edges of each section with the mid green flock so as to prevent strange lines cutting off between sections. Then I gently added light and dark tones before giving the whole thing a hit with mid green flock. I simply sprinkled everything on, as just chucking on the flock creates a lot of waste.
    After this I started detailing....
    Some links for folks.
    Materials.
    Sally 4th, suppliers of the Terra-Former Tiles.
    Arcane Scenery, suppliers of the various flocks, foliage etc.
    B&Q, for the polystyrene, woodglue etc.
    Tutorials.
    TheTerrainTutor
    Lukes APS
ID:	240670Click image for larger version.
ID:	240671Click image for larger version.
ID:	240673Click image for larger version.
ID:	240674Click image for larger version.
ID:	240676Click image for larger version.
ID:	240677Click image for larger version.
